camber
Old Feb 3, 2007 | 09:04 PM
dv3's Avatar
dv3
Default camber
when i have my car alighned can i have guy adjust the camber slightly negative or does this require a kit?
Old Feb 3, 2007 | 10:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: camber
It is only adjustable so much w/ the factory settings. Why do you want a neg setting?
Old Feb 3, 2007 | 10:50 PM
dv3's Avatar
dv3
Default RE: camber
ive read thatstock is o ...but is better at like -3/4
is that wrong
Old Feb 3, 2007 | 10:51 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: camber
I would have it set for the factory settings. Otherwise you will have premature tire wear.
Old Feb 3, 2007 | 11:42 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: camber
My friend that did mine set it to -1.3° for slightly more agressive handling, he said it wouldn't mess up my tires. Is your car lowered?
Old Feb 4, 2007 | 12:19 AM
dv3's Avatar
dv3
Default RE: camber
no but im looking at getting some lowering sprins outta a parts car...lol......not sure what they are but it sittin on 18's so not to low ...right now stock .......no matter what lets say i drop it 2" then what
Old Feb 4, 2007 | 12:52 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: camber
if you get lowering springs you should probably get caster/camber plates, and then you could have it set whereever you want with ease. If you want a little more camber maybe go like -.5° past stock.
Old Feb 4, 2007 | 01:52 AM
dv3's Avatar
dv3
Default RE: camber
ty
reply
Old Feb 4, 2007 | 01:59 AM
Maxwelhse's Avatar
Maxwelhse
Default RE: camber
My car is at -3/4 as well for the reasons mentioned above. A tire wear issue may come up, but not nearly as fast as the rears!
Old Feb 4, 2007 | 02:04 AM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: camber
mine is set at -1.3 both sides
straight as an arrow and no tire wear
vargas
Jun 17, 2017 12:17 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
