Camber Plates
Old 02-04-2007, 09:30 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Camber Plates
ORIGINAL: HC_CrAzYHoRsE
doesn't matter, they assume you'll buy from them or at least get it installed there... -1.3 doesn't sound problematic, most people go for -0.5 to -2.0 for optimal handling. unless there's any noticeable uneven wear on the tires?
.5 to -1.0 is allowable. Anything after that will begin to wear tires. -2.0 is def to far negative and WILL wear the insides of the tire. The -1.3 reading they gave you is def stretching the limit for normal wear. I would look into a fix of some sort.
PRO50SC is offline
Old 02-04-2007, 09:34 PM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
ORIGINAL: PRO50SC
i did mention "for optimal handling"
HC_CrAzYHoRsE is offline
Old 02-04-2007, 09:38 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Haha, yeas I did see that.
PRO50SC is offline
Old 02-04-2007, 11:28 PM
gspfunk
gspfunk's Avatar
I went w/ Maximum Motorsports CC plates. My caster was maxed out and I'll be dropping it at some point anyway, so I went ahead and got them....great quality.
gspfunk is offline
Old 02-05-2007, 12:09 PM
LesteR723
LesteR723's Avatar
whats the point of a new camber plate? i see them in a package for sale with maximum motorsports but i dont want to waste the extra money if i dont have to...
LesteR723 is offline
Old 02-05-2007, 02:19 PM
vtecwho
vtecwho's Avatar
i have the same problem, but my 93 gt is lowered 2 in (i dont recomend 2 in!) my tires are getting inside wear and the shop said that my springs were sagging and camber was maxed. the car has eaten through two sets of front tires and now im just going to get springs that drop less. hopfully that will stop the problem!!
vtecwho is offline
Old 02-05-2007, 04:22 PM
w8less
w8less's Avatar
get some x2ballljoints and a bumpsteer kit vtecwho. should add with handling and give u the extra adjustments required to fix the alignment
w8less is offline
Old 02-08-2007, 06:03 PM
gspfunk
gspfunk's Avatar
ORIGINAL: LesteR723
They give you a lot more range of adjustment than stock CC plates. They will allow you to have correct caster/camber w/ drop springs as well. The offset rack bushings, sway bushings, and X2 balljoints are also a good idea. Anything to promote more accurate steering geometry will prolong the life of your parts.
gspfunk is offline
baddog671
07-26-2016 01:20 PM
Lethaldosage423
10-19-2015 12:12 AM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Camber Plates
