351w and turbo...Are these good heads?
Old 02-05-2007, 04:55 PM
  #21
88BlueGT
88BlueGT's Avatar
Default RE: 351w and turbo...Are these good heads?
4" might be a little big but I would definetly go with a 3"+ from what I have read on turbomustangs.com. I would talk to those guys over there, there are some knowledgable turbo guys over here but there are TONS over there and will help you alot.
88BlueGT is offline
Old 02-05-2007, 05:08 PM
  #22
ruger311
ruger311's Avatar
going 76mm turbo so i can hit the high notes,,, hehe 76mm will put me up around 700-750RWHP on about 12#s boost that should be around 920FWHP the 60 and 66mm are only capable of round 700-750FWHP and my 347 breathes hard so gotta have enough flow also, i know that i will have just the slightest bit more lag than the 60 or 66 but from guys i have talked to with the 60 and 66 they dont experience "lag" b/c the engines climb so fast and push lots of air through them, so in order for me to push my lil toy to the low 10s or high 9s i gotta have the HP b/c of a vert i already start 400#s heavier than the notch, so i gotta find the ponies to take care of that!
ruger311 is offline
Old 02-05-2007, 05:29 PM
  #23
88BlueGT
88BlueGT's Avatar
what kind of trans are you gonna be running ruger?
88BlueGT is offline
Old 02-05-2007, 05:32 PM
  #24
ruger311
ruger311's Avatar
here is my full setup as of a long time ago,, hehe actually round august or something,, running through TKO 600
1989 Ford Mustang GT Convertible
Engine
347 Stroker
Dart IE 4 bolt Main Block
Scat Forged 4340 Crank
Scat Forged 4340 H-Beams
JE Pistons 8.5:1 Compression
Comp Cams XE282HR camshaft
Comp Valves/Guide Plates/Springs/Retainers/Lock/Pushrods
Speed Pro Plasma Moly Rings
ARP bolts
Professional Products Harmonic Balancer
Moroso Main Cap Girdle
Moroso 7qt Oil pan
Clevite Bearings
Melling HV Oil Pump
Fidanza Flywheel
EPW 1.6F Roller Rockers
Racing Head Service 200cc 64cc Heads
Cobra Valve Covers
BBK Underdrive Pulleys
New water pump
New power steering pump
Cooling
Northern 2 core Aluminum Radiator
Flex-a-lite Black Magic Extreme Fan
Intake
Edelbrock Performer 5.0 RPM II
Accufab 75mm Throttle Body Blank EGR
PRO-M 80mm MAF
FRPP 42# Injectors
Stock Fuel rails w/ BBK FPR
Autometer FP guage
Walbro 255lph fuel pump
Tuning
Dyno Tuned A/F and Timing
Ignition
Crane Hi-6 Digital Ignition
Crane Coil
Stock Distrbutor
Accel Cap and Rotor
New Ignition Module
Taylor Plug Wires
Autolite 25 sparkplugs
93 Cobra G3 Alternator Conversion
93 Cobra High Torque Mini Starter
Optima Red Top Battery
Exhaust
Hooker Super Comp Unequal Headers 1 5/8†w/ 3†collectors
Flowmaster 3†American Thunder Exhaust System (dumped)
New O2 Sensors
Transmission/Driveline
Tremec TKO600
Steeda Tri Ax Handle
Mcleod SFI Bellhousing
Mcleod Dual Friction Clutch <------------- sucks ordered a new Spec Stage 3+
FRPP Aluminum Driveshaft
Driveshaft Safety Loop
Stock 8.8†Housing
3.55 Gears
Eaton Pro Posi Locker
Moser 31 Spline Axles 5 Lug
Moser C-Clip Eliminators
21 tooth speedo gear
BBK adjustable clutch cable and quadrant
Suspension
Maximum Motorsports Road and Track Box
MM Strut Tower Brace
MM 4-Point K-Member Brace
MM Full Length Subrame Connectors
MM Panhard Bar with Aluminum Rod
MM Heavy-duty Rear Lower Control Arms
H&R Race Springs
Bilstein front struts
Bilstein rear shocks
MM Caster/Camber Plate
MM Urethane Pinion Snubber
Front spring isolators
Rear spring isolators
Solid Steering Shaft
MM Aluminum Rack Bushings, center drilled
Front Swaybar bushings
Front Swaybar end link bushing kit
Front control arm bushings, urethane
SN95 Front Spindles
New Hubs
New Ball Joints
MM 6pt Bolt/Weld In Roll Cage w/ Swing out door bars
Exterior
Cervinis Heat Extractor Hood (coming soon)
Saleen Wing
Shorty Antenna (coming soon)
Wheels and Braking
2003 Cobra 17x9s Chrome
Nitto 555DR 275/40/17 Drag Radials on back
Nitto 555 Extreme 275/40/17 on front
2003 10th Anniversary Cobra Calipers Red on front
13†Proslot slotted rotors on front
New Stock drums and pads on back
93 Cobra Master Cylinder and distribution block
MM stainless steel brake lines
Interior
Florida 5.0 Custom 6 gauge cluster w/ autometer gauges
All Black interior minus the rear seat
Corbeau LG1 Microsuede (coming soon)
ACC Black Carpet
New Black Door Panels w/ SVT logo
New 2006 Retro Shift **** (coming soon)
Audio
JVC El Kameleon 50x4
4 6.5†Infinity Perfect Kappa w/ tweeters (coming soon)
2 4x6†Infinity Reference (coming soon)
1 JL Audio 12W7
JL 1000/1 Amp
Kinetik HC1400 (coming soon)
ruger311 is offline
Old 02-05-2007, 05:34 PM
  #25
88BlueGT
88BlueGT's Avatar
wait... so your already running the dart block? and you dont have the turbo yet right? do you just plan on running the exhaust that comes with the hellion kit?
88BlueGT is offline
  #26
ih8chevy
ih8chevy's Avatar
first off my man with our cars 550 wheel wil get u 9's, second off the canfield heads you want are the 2 something they are one hte site of camshaft innovations, so just go there and look under heads, they are real good and will flow as well as the afr 225. third off with that setup ur gonna be makin well into the 650-700 wheel hp range and u should be hittin high 8's which dont really make for a streetable car. fourth i do support the custom ground cam, for ur setup the trick flow stage 2 wont do much.
good luck
ORIGINAL: 90Mustangfan
plans...make 550rwhp reliable, running 91oct, with 351w and turbo on 10psi intercooled. its going to be a daily driver(local) on a 87-93 GT...street/strip. run mid 11's all day at any given time..and I dont want it to be track/strip fast where its fast because of susp or or launch(60ft times)and runs 11.5 at 115mph...I want supra fast where it ran 11.5 and trapped at 135+...If you Know what I mean. where the turbo/motor pull really hard on the top end.
ih8chevy is offline
Old 02-05-2007, 05:45 PM
  #27
ruger311
ruger311's Avatar
88Blue, i just got the Dart block, rebuilding right now, as for the turbo going with HP 76mm, it is still going to be a street car, DD, and see the track prolly less than 15-20 times a year, want the turbo so i can adjust boost run 8-10 on the street and 12-17 on the track depending on fuel at the time
ruger311 is offline
Old 02-05-2007, 06:11 PM
  #28
88BlueGT
88BlueGT's Avatar
damn a DD ?!?!? I would invest a few K into another car.... you will save that in gas in the first month lol
88BlueGT is offline
Old 02-05-2007, 06:14 PM
  #29
ruger311
ruger311's Avatar
naw,, right now when i had fugged up rings it put down 373RWHP and 427 lb ft TQ and it got round 16-18MPG thats pretty damn good, just gotta keep my foot outta it, so with round 550RWHP on 8#s boost should get round 12 or so maybe a lil less just depends on if i see some rice up ahead or not,, should be fun, i got 3 other beaters,, hehe got a yukon xl, 64 f100 my muddin truck, and 88 camry <------ BEATER,, oh yeah and couple of motorcycles too
ruger311 is offline
Old 02-05-2007, 08:08 PM
  #30
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
Hell I dont think there is a manual trans stronger than G-force that arent too pricy G- force is one of the best for trans
90Mustangfan is offline
Quick Reply: 351w and turbo...Are these good heads?
