347 stroker power?
Old Feb 5, 2007 | 03:17 PM
93reefblue347AFR's Avatar
93reefblue347AFR
Default 347 stroker power?
Guys youneed to tell me what you think? I'm building a 347 stroker for my 93 stang. The motor parts consist or a stock block thats been pressure checked and everything eles bored exc.. Scat forged crank with main girdel, Scat forged H-Beams, JE forged pistons 10-1 comp., AFR 185cc heads and i swapped out the original valve springs because the stocks off the 185s can only handel 550lift, Cam is a Ed Curtusat Flowtech induction its like 576/582 or somethin roller cam, roller lifter,and scorpion roller rockers, my intake is a Trick Flow track heat, 75mm professional products throttle body and 75mm spacer, 42lb Ford Racing injectors, 90 mm mass air, and flowing it out will be a set of MAC 1 3/4 shortys. Oh yeaI bought a set of those valley girdel PRO girdel,So guys my goal was to make 400- 425 HP and i dont know about torque, so give me an idea about what you think my motor will make and what you think about the quality of my parts and my combo. by the way my name is Ryan Cellitti i live in Rockford,IL and im 20 and this is my first forum poat
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
