Door?
RE: Door?
100% positive all the doors are the same except for verts and t-tops.
the driver door on my 90 gt is from a 93lx 3 cyl. the only diff is the plastic molding that goes through the middle but 50resto has them
i found my door on craigslist for $100 then had it sanded, painted and mounted for $300
as far as the door internals, if they still work then you can use them from the banged up door, i did cause the lx was manual windows but mine is power
RE: Door?
You will need a '91-'93 fender since the opening is different than '79-'90.
Doors are the same '87+ (older ones are the same shellbut might require drilling new holes for inner parts and door panels).
You can get a manual door and just transfer all your power stuff to it fairly easily. Just unbolt the inner parts (or drill out the rivets depending on how that stuff is attached) and bolt/rivet them on the manual door.
That shouldnt take more than a few hours. Ive done that on several cars before (but not a Mustang).
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
