Mustang Guru Needed
RE: Mustang Guru Needed
Second AdderMk2 on the exhaust possibility........
Yep.....but you could also set it to 34° - 36° or less and leave the SPOUT off, while you get it fixed ....the only problem it would cause is for warm engine cranking . FYI...... there are a few setups that simply lock total timing without any problems.....this takes the spark control from the ECM out of the picture.
ORIGINAL: 92cobra
Alrighty thanks for your help joel, one more quick question, if the tfi replacement doesnt work, could i advance my timing to say 14* if theres no ping, and run her without a spout connector?
ORIGINAL: 92cobra
oh before the h pipe, well considering its currently snowing, and almost negitave in temp outside, i doubt today would be the day to do it. However I will still go get the tfi module and have the shop install it for me. I would do it however i dont have the tool required and im sure they do.
I dont have a timing light and or the knowledge/tools to advance my timing, but i was thinking about having the shop do it for me thats going to install the tfi AFTER i make sure the tfi solves my problem. Stock timing is at 10 whats it under at wot?
i already do lol, thats the other thread i was going to make. The problem just occured. Its about -5 outside, and whenever i start it, i have to give it some gas and she will stall if i dont continue to give it gas, and let it warm up abit. I found the solution to be to start it and then drive it kinda hard for awhile, not like above 3k hard, but like putting my foot on it.
ORIGINAL: 92cobra
this was also the night after i washed my motor... i guess i shouldnt was the engine in 5° weather
YES YES YES YES JOEL ADDER VRISTANG ETC, i love you all!!! sorry for the caps but i changed the tfi module, set the timing back to 10degrees base, and shes running amazing!!! THANKS SO MUCH GUYS!!
SANDY21
08-17-2015 02:41 PM
