Whats the Difference?
ORIGINAL: FuzzyDiceRule
Between Power shifting and Speed Shifting, because ive heard that T-5s cant take powershifting but speed shifting is ok, so whats the difference?
its essentially when u have the car in neutral and u try to smash it in to gear without putting the clutch in, the gears grind together and make like horrible noises. if u do it hard and fast enough then it might go in but then its puttin stress on the gears and could eventually lead to stripped gears, bent shafts, just basically a ****ed up transmission
it does, i hear it will kill the trannys almost instantly, but i HEARD that
a, whats IIRC
b, not using the clutch, like getting the engines RPMS to match the speed of the car and pulling it into neutral and then same thing into next gear?
a, whats IIRC
a, whats IIRC
a, whats IIRC
