24# injector & fuel pump ??
Ok, I've searched the threads regarding this question but still kinda up in the air. When I put 24# injectors in my car will the stock fuel pump supply enough fuel to feed them. The motor is no mountain motor however it does have aftermarket heads, cam intake, TB, M/A, and getting ready to install my wet kit. Any replies are greatly appreciated.
RE: 24# injector & fuel pump ??
255 is the way to go. It is definitely big enough for what you have now, and is big enough to leave you room for more mods in the future. The key is to get an adjustable fuel pressure regulator and a fuel pressure gauge mounted int he car so you can dial it in right. This adjustability is what allows you to use this same pump as you go faster and faster, without worrying about it being overkill.
ORIGINAL: veto227
Cool, Now I guess I need to do a search on the way to change the fuel pump.....
BTW, I've been running 24's with H/C/I since last summer with no issues. I'm upgrading since I'll have the tank down anyway, under the "be prepared" thought process.
