Highway Gas Mileage
RE: Highway Gas Mileage
ORIGINAL: 90Lxstanger
if you have a odometer just take the mileageyou get in a 1/4 dividied by 3.85(the gas in a 1/4 tank and your set......), this is based on a 15.4 gal. tank which all mustangs should have stock, or at least i think
I have dumps as of now, with no cats, I have to get a catted h or x pipe, I have been looking, pricey, trying to find a used one, but, then again that could be a waste of money if the cats are no good. Emissions blow, and no, I am not going to move to another state either, j/k.
ORIGINAL: LTnone
Bad idea, leaves a lot of area for guesswork. Do this instead: Fill it all the way up (to a specified point, like when it clicks off 3 times). Reset the odo at that point and drive. When you fill up again, fill up to the same spot (3 clicks off or whatever you decide), and divide the number of miles on the odo by the amount of gallons you put in. Most accurate way
Matt's 95 Stang
10-05-2015 07:16 AM
