Which axels for 5 lug 18" Saleens on a Fox?
I'm planning on doing a 5 lug disk conversion on my 91 notch for better brakes and so I can fit 18' saleen wheels (5lug). I'm just not sure whether to use stock length axels from a ranger/aerostar or the longer sn95 axels. I wanna fit the widest tires possible in the rear without them sticking out past the body or rubbing my exhaust. Anyone got the answer for me?
RE: Which axels for 5 lug 18" Saleens on a Fox?
it depends on which saleen rims you use... the backspacing is what you goin to need to worry about that will tell u how it will be positioned in the axle. each relicated saleen rim has a lil different diminstions... if u can get ahold of hte dimisions throw them up here... i mayb be able to run a few numbers... i dont own a fox tho so i dunno how easy it will be
Well to give you an idea...
I have 03 Cobra's 17x9's with -26mm of offset, WITH a once inch spacer on stock fox axles... 255/40/17 and the tires are flush with the body. I plan on using SN95 axles (1/4 inch shorter then my current setup) to bring in the tire just a little bit.
I found the Saleen 18' replicas in 18x10 with a +45mm offset and also with a +22mm offset. I havent done the conversion yet but I'd rather use the sn95 axels. Again, I dont want the wheels sticking out and I'd like to use 285mm tires.
01-21-2016 01:30 PM
mungodrums
09-28-2015 10:54 PM
