MASS AIR FLOW SENSOR
Old Feb 23, 2007 | 05:41 PM
great 8's Avatar
great 8
Default MASS AIR FLOW SENSOR
I Just wanted to know is it mandatory that if u have 24lbs injectors that u have to have a MAF thats recaliborated for 24lbs injector.If so wat will happen if u use the stock MAF sensor with 24lbs injectors?
Old Feb 23, 2007 | 05:43 PM
7upedition's Avatar
7upedition
Default RE: MASS AIR FLOW SENSOR
dial up c&l and order a 24lb MAF sampling tube and change it dude, don't mess with the a/f ratio, that is only really a way to trick the digital output of the MAF to the computer so it thinks its running a cal'd 24lb'r, but it's the most typical way of doing it, why the increase in injector size?
Old Feb 23, 2007 | 05:45 PM
88BlueGT's Avatar
88BlueGT
Your car will run like sh*t. Its not MANDATORY but you will need a tuner to correct everything if you want to swap out the injectors and not change the MAF.
Old Feb 23, 2007 | 05:55 PM
great 8's Avatar
great 8
The injectos were already on car when i got it but the sensor is stock i just found that out about the sensor beening stock. It runing like **** with the stock one on there. Ima just get the sensor for the 24lbs
Old Feb 23, 2007 | 05:58 PM
7upedition's Avatar
7upedition
good idea, if you have the cash upgrade the MAF to a 76mm from c&l tuned to 24 lbs....
http://www.cnlperformance.com/76mm_86-93.html
Old Feb 23, 2007 | 06:11 PM
great 8's Avatar
great 8
yea aite
Old Feb 24, 2007 | 05:22 AM
vristang's Avatar
vristang
It is possible that the previous owner knew what he was doing and installed a 93 Cobra computer and MAF along with the 24lb injectors.
Check the part number on the MAS. The Cobra will be 'F1SF' and the A9* series MAS will be 'F1ZF'
Have you pulled the codes?
C&L is not the best quality MAF meter. They work great for many folks, but in some vehicles C&L will never run right.
PMAS may be a better option...
With that said, I ran a C&L for 10yrs with no noticeable problems...
jason
Jb145700
Aug 21, 2022 06:37 AM
1996cobraconvertible
SVT Forums
13
Jan 7, 2016 04:50 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
uedlose
Sep 10, 2015 03:30 PM
