Winter comming to an end..
I guess since in the winter I can't drive my car, I tear it apart and work on things...here is a list of what I did or am doing to my car this year:
-Fabbed up a fuel pressure gauge, it goes on the rail
-Fabbed up a new EGR delete spacer
-Put lower control arm reinforcments in
-Put in new adjustable lower control arms
-Fabbed up an air filter adaptor for my 70mm MAF
-Fabbed my own cold air kit
-Converting to MAF from SD
-Hiding wires in engine compartment
-New adjustable fuel pressure regulator
-70mm BBK throttle body
-Shift light
-MSD cap and rotor kit
-New red Ford racing wires
-New dead soft aluminum header gaskets
-porting headers/cleaning the welds up
-New BBK X pipe
-New black headline and visors
-Ported my upper and lower intakes
-Drilled and tapped a new hole in my lower intake for my temp gauge.
-Plugged my EGR port in my lower intake
That is all I can think of right now, and in my opion, it is around a $1000 well spent. I also just picked upa pair of 10 holes to put some DR on, so soon I will be picking up a set of 255/60/15 MT for them. I hope I can get my 1/4 with most of this work.
What have you guys done to make winter pass??
-Shift light
-New BBK X pipe
RE: Winter comming to an end..
I put rebuilt my T5 with all new G-Force internals with mcleod clutch kit and a Pro5.0 to top it off. I also put on some adjustable granatelli weight jacker lowers and adjustable granatelli uppers. I was unable to keep my rear sway bar on tho, gotta find out how to make that work somehow.
ORIGINAL: 5.0stanger
-Shift light
-New BBK X pipe
-Shift light
-New BBK X pipe
well, over winter I put in a 2 stage nitrous kit, with a window switch, and fp saftey switch, and a forged stroker bottom end, new wideband o2, aluminum flywheel and spec stage 3 clutch, and a pms
ORIGINAL: Goosepoop302
i think you missed the memo. we got 14 inches of snow on friday night and we just got dumped on last night supoidly another 14 inches.... winter aint over yet.
ORIGINAL: silver91gt
Soldier GT
09-08-2015 01:28 AM
