Bottom Bolt of water pump.
Old Feb 25, 2007 | 10:34 PM
musclemustang94's Avatar
musclemustang94
Default Bottom Bolt of water pump.
I cant get a socket on it...please dont tell me I have to take the balancer off...and if I do how the frick do I get it off with out an air hammer?
Old Feb 25, 2007 | 10:46 PM
92hatchLX's Avatar
92hatchLX
Default RE: Bottom Bolt of water pump.
Can you get a wrench on it? I wouldn't be using an air hammer to take your water pump off. Did you mean animpact wrench?
Old Feb 25, 2007 | 10:49 PM
Liquid_02's Avatar
Liquid_02
Air hammer to pull off the balancer?! WTF. That is the most obscure way I've ever heard of that being done, and i'd throw the balancer out of balance... man.. that could hurt a lot of things. A puller would suffice. Maybe you mean an impact? put the car in gear if it's a standard, if not, depending on the way they crank, (forget which it is) you can always put a big breaker bar on it so it rests on the frame while on the balancer and crank the engine over. if auto, gotta jam something in the flywheel to stop it from turning.
Anyway... don't know what bolt you're talking about, but, I know I had my balancer on mine when I did it. Try a wrench.
Old Feb 25, 2007 | 10:52 PM
Wisconsin 5.0's Avatar
Wisconsin 5.0
You should not have to remove your balancer just to get a H2O pump off...try a small box-end wrench, or look for some other wrench that will fit.
Old Feb 25, 2007 | 10:59 PM
musclemustang94
hmm..maybe that bolt isn't holding the pumpon
Old Feb 25, 2007 | 11:02 PM
silver91gt's Avatar
silver91gt
use a deep socket and 3/8 ratchet some are a 15mm and some are a 13mm, there is no bottom bolts, only on the top and side.
Old Feb 25, 2007 | 11:29 PM
ZachW04Stang's Avatar
ZachW04Stang
Theres2boltsat the bottom that hold a plate on the back of the water pump. You don't need to touch them to get the water pump off. But if your putting new one on make sure they are tight before you put the water pump on.
Old Feb 25, 2007 | 11:30 PM
musclemustang94
Hmmmm...ok thanx. I guess the pump is just stuck on there, i figured that bolt was holding it on.
Old Feb 25, 2007 | 11:37 PM
musclemustang94
ORIGINAL: ZachW04Stang
I have all the bolts off except that one on the bottom and the pump wont come off. I just looked
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
jerrytubes
Oct 23, 2015 12:11 PM
