help with stripped thread
Old Feb 26, 2007 | 04:55 AM
bullet's Avatar
bullet
Default help with stripped thread
today i was taking off my x-pipe to go get smogged. while i was on the last header flange it would not come out so after forcing it i look at the bolt and the top is all shiney and flat no more threads. that wouldnt of been a big deal but then i look at theheader where the bolt screws into and it looks the same no threads just a mangeled mess and now i cant get the new stud back in it just strips out, will i be able to just re-thread it. any ideas or info would be great cause ive never done it before. also its not the stock headers or i would just get new ones. thanks
Old Feb 26, 2007 | 05:22 AM
mattdel's Avatar
mattdel
Default RE: help with stripped thread
you need a tap & die set, and rethread both with the proper size.
Old Feb 26, 2007 | 05:36 AM
Mowin8603's Avatar
Mowin8603
well if i understood your story correctly here.. you have aftermarket headers and i guess they have studs in them? i would say cut the studs off with a saw zaw or something, and then drill the rest of the bolt out and put a bolt in to replace it. you will need a bolt, nut, and a prolly 3 washers that are large enough to not go through the holes.
just my $.02
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
wraith777
Sep 28, 2015 10:49 AM
GLOCKer
Sep 28, 2015 07:36 AM
