I have got a stumper, passengerside window
if the window is up, eather switch can roll it down. If the window is down and you press the the drivers side switch nothing happens. If the window is down and you press the passenger side switch the window goes up very very slow and only goes up half way. If you press the drivers and passenger side together the window goes all the way up with no prolbems. What is the deal?
the stuff I replaced, the motor and passnger side switch.
RE: I have got a stumper, passengerside window
I think that the passenger side switch grounds out through th driver side switch. IT sounds like there's some corrosion problems on that side of the switch.
I am having the same problem with my pass. window and im trying to figure it out now.If I come up with anything I will let you know.I just upgraded my alt. but havent checked to see if it made a diffrence.Im also going check all my connections for bad or loose connections.When i used to try to put the window up it would use a lot of volts to do it.Assuming bad connection or motor on mine.But going to work on soon.
DreadPirateRoberts
09-26-2015 02:11 PM
mungodrums
09-22-2015 08:36 PM
wishinsky
09-21-2015 09:48 AM
