Ordered kill switch, says to wire it to IAC valve ?
Old Mar 1, 2007 | 01:36 PM
Scalihoo's Avatar
Scalihoo
Default Ordered kill switch, says to wire it to IAC valve ?
Theres a guy that sells these neat little insulated switcheson E bay for 10 bucksso . The directions say to wire it into the blue & white wire a couple inches from the connecter to the IAC{Idle Air Control} valve ??
I did a Google & found nothing about this location for kill switches, then Emailed the seller & he said it's his " invention " & I wouldnt find anything on the web aboutthis location , LOL
Anyways, what do you guys think, any drawbacks from trying this location , will it even work I wonder?
thanks,
Scali
Old Mar 1, 2007 | 01:44 PM
ttoppedaerocoupe's Avatar
ttoppedaerocoupe
Default RE: Ordered kill switch, says to wire it to IAC valve ?
got a link?
Old Mar 1, 2007 | 01:45 PM
Red FIVE O's Avatar
Red FIVE O
ive only heard of kill swithes for the fuel pump.
Old Mar 1, 2007 | 01:47 PM
50Trippin's Avatar
50Trippin
I don't know which wire you would connect it too but i think it would work somewhat...... if the IAC isn't working i would think the car would still start if you pushed on the throttle. all that would do is make it not want to start/idle on it's own.
Old Mar 1, 2007 | 02:25 PM
Scalihoo's Avatar
Scalihoo
Yeah, I think it would run bit stumble like a SOB.
link is www.killswitchcentral.com
Old Mar 1, 2007 | 02:39 PM
ckyguy68's Avatar
ckyguy68
The car will run fine without the IAC, just probably idle low when cold. I unplugged mine for a while when i had a problem with surges in between shifts. Car still ran great. The idle air controller does exactly what its called. It controls the air at idle, and thats it! I would just look for a DIY kill switch walkthrough... you shouldnt even need to buy a kit.
Old Mar 1, 2007 | 03:38 PM
Scalihoo's Avatar
Scalihoo
It's not really a kit, I wasnt even expecting directions, someone here on this forum linked this guys site a couple weeks ago &I ordered one. I'm only asking because it seemed a unique place for a KS where the thieves are less likely too look or know about but I'm going to wire it into the fuel pump relay or ground or maybe the coil..
mustangchef
Sep 4, 2015 08:08 PM
whatsup62
Sep 3, 2015 01:38 PM
Steve@CJPP
CJ Pony Parts
Sep 3, 2015 11:43 AM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 2, 2015 08:40 PM
