Clutch making noise???
I have a 95 GT and cannot figure what exactly this noise is andif Ishould be worried at all. It sounds like it is coming from the clutch. It sounds like something is rubbing against something else but only does it when the car is cold. I was told not to worry about it, what do you guys think?
RE: Clutch making noise???
I have the same problem, I'm just going to replace the clutch and check out the flywheel while I'm under there. I had a high pitch noise I could control with the clutch but now I'm getting the rubbing ur talking about too.
definatly your throwout bearing, minds well replace the whole clutch if your gonna take it down.
but its most definatly that, i had the same problem buddy. and i have a 95 too
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
