Roller rockers?
Old Mar 20, 2007 | 12:25 AM
mustanggt929450's Avatar
mustanggt929450
Default Roller rockers?
i have a 5.0 motor out of a 92 mustang its strokedto 347 .30 over kb pistons with valve releaveswith victor jr aluminum heads 2.05 1.60 what roller rocker ratio should i use? and why?
Old Mar 20, 2007 | 12:29 AM
my77stang's Avatar
my77stang
Default RE: Roller rockers?
100% of that answer depends on the cam thats in there. btw victor jr. heads are nice, that things gonna run pretty nicely when its together
Old Mar 20, 2007 | 12:34 AM
mustanggt929450
im usin a cam from comp cams part number 35-450-8 i dont have the specs infront of me
Old Mar 20, 2007 | 01:11 AM
tinman's Avatar
tinman
It's probably meant to use 1.6 ratio rockers..........
Old Mar 20, 2007 | 01:12 AM
my77stang's Avatar
my77stang
yeah i looked it up and its .598/.598.......... you dont need any more lift than that LOL
Old Mar 20, 2007 | 01:21 AM
AdderMk2's Avatar
AdderMk2
Banned
I dont think your going to be able to fit those heads on that motor.... I believe your gonna need atleast .040 overbore... I heard rumor that large 2.05 valves will flow badly on small bore motors..... you MAY want to consult an experienced engine builder before going any further
Old Mar 20, 2007 | 01:27 AM
my77stang's Avatar
my77stang
meh, i wouldnt worry about that, the main thing that effects flow is not having the chambers in the head unshrouded..... which isnt a problem on aftermarket heads designed to work with valves that big.
btw the dif between .030 and .040 is only gonna be .005 on the side where the intake vavle is, thats not enough to mean anything at all.
no TS for you today Adder?
Sixer4Life
Oct 12, 2015 04:26 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
uedlose
Sep 30, 2015 08:01 AM
Sixer4Life
Sep 28, 2015 07:05 AM
JDWalton
Sep 24, 2015 08:47 PM
