welder
Old Mar 21, 2007 | 11:33 PM
stanglx2002's Avatar
stanglx2002
Default welder
is this a good welder for basic welding of parts and the holes in the engine bay??
http://cgi.ebay.com/New-125-Amp-Flux...QQcmdZViewItem
Old Mar 21, 2007 | 11:48 PM
97BlackStang's Avatar
97BlackStang
Default RE: welder
Thats probaly the worst duty cycle i have ever seen on a welder. But I would have my doubts about that things performance, especially since I own a Miller 220 volt, which will do thin guage if you know what your doing.
Old Mar 21, 2007 | 11:55 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: welder
I'd get a gas welder. A clarke welder comes with everything you need but the bottle and gas for $400. That thing is just going to make a ton of splatter thats going to be a bitch to clean up. The clarke welder also works on 110 volts.
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: welder
You really don't want to use flux core on sheet metal, you will do nothing but burn holes. I have a very hard time doing it and I am a welder by trade. Plus that welder is just plaine junk, if it ever breaks good luck getting parts for it, plus if your a rookie welder it will make learning not easy. Look into the Lincolns at Home Depot, they run in the $4-500 range but it will be a tool that you can own for a lifetime.
bradleyb
Nov 4, 2006 01:26 AM
atomsk680
Jul 23, 2006 02:02 PM
6mustang6
Jun 9, 2006 02:45 PM
charged90lx
Jan 3, 2006 06:47 PM
mustangdemon01
Oct 11, 2005 10:42 PM
