gas tank
gas tank
I just installed an adjustable fuel regulator and fuel pump. Now it's getting any fuel presure at all. this the secound fuel pump, i tried cleaning the tank out but I might not have cleaned it good enough. Should I buy a new gas tank?
RE: gas tank
maybe a little more info??? is the pump turning on? if it is did you cycle the pump numerous times to get fuel back in the lines? what caused you to replace the pump in the first place? was it clogged? how'd you clean the tank?
mrappe
09-26-2015 10:16 AM
