Got air?
Old Mar 26, 2007 | 11:27 PM
tmajikman's Avatar
tmajikman
Default Got air?
Finally got my ac working, no new parts needed. I knew it would run a little slower, but it now has detonation under high rpm, without the air on there no detonation, should I just lower my timing a bit to fix this, btw I can now set my timing, I found a pointer, just have to install it.
Old Mar 26, 2007 | 11:34 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Got air?
Well, why would you want to run wot w/ the ac on? Kinda pointless. I would leave it be. If I'm gonna throw down, I just shut off the ac.
Old Mar 26, 2007 | 11:39 PM
thunderjet429's Avatar
thunderjet429
no parts ????? somthin unplugged[sm=WTFsgign.gif]and +1 on the rape'n the car with ac on...
Old Mar 26, 2007 | 11:53 PM
tmajikman's Avatar
tmajikman
no, it's not wot, it was around 3800 and up, I just wanted to check and see if everything was good. As far as parts go, I did find a loose fitting, and I guess I just did not get enough freon and oil through the system.
Old Mar 26, 2007 | 11:58 PM
AdderMk2's Avatar
AdderMk2
Banned
my a/c has always worked.... I just roll my windows down
Old Mar 27, 2007 | 12:01 AM
tmajikman's Avatar
tmajikman
ORIGINAL: AdderMk2
If I had RI weather I would too, there is just to much high heat and high humidity down inGA for a daily driver, at least for me... I am originally from MI and I do like the cooler summers.
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
