Recommended Tire Pressure
RE: Recommended Tire Pressure
the chalk method is a GREAT way to do it, however the numbers will change slightly with different tires, just cuz those are perfect for your set up and tires doesn't mean that they will be the for his tires and setup maybe his tires are sofer and need that exrta 2 or 3 PSI to wear the same as yours did.. i mean yea thats is a good starting point but every tire is different so making adjustments as you go is the best method or using chalk
ORIGINAL: mustangguy82
ok dont listen to the tire guy, i used some chalk on my tires and 30 in the front and 26 in the rear is were they wore the chalk off even. its not like i just magicaly came up with those numbers[sm=signs003.gif]
ccdguy
09-19-2015 05:20 PM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
