How do you take the door panels off?
RE: How do you take the door panels off?
just unscrew everything and pull the panel...the clip will come undone. There are two bolts under the door panel the rest are screws. Ive done it so many times and none have broken or anything. Just make sure you remember where the screws go.
how do you get the top part of the door panel off
like up around the edge and the little silver piece bye the window
and it seems like somethin in the middle of the door is holdin it on
after everything is unscrewed and all that have your window down and just kinda pull up. It wraps around the top. About the screws...normal size..if you mean the bolts not sure...trial and error. The two bolts are under the arm rest make sure you get those off first before you try to get it off. just pop off the two little covers on the underside of the armrest
You can buy more from alot of places 50restro or mustangsunlimited you wont need to believe me
ORIGINAL: pastfast125
I'ma steal your thread, where can I get new clips for my panels? Oh and what size are the screws that hold everything?
