U&L Control Arm & Spring Install
Hey guys, Installing some Upper and Lower Control arms and Cobra springs in the rear tomorrow. Just wanted to know in advance what I'm getting myself into. I noticed some type of rubber above the springs in the rear, I didnt know if that should be removed or what not. Just bassicly any information from anyone who's done it before is really aprecaited.Thanks alot
RE: U&L Control Arm & Spring Install
Drilling out the bushings is an easy way to get them out if you don't have anything to press them out... The springs are very simple to install, everything is straightt forward as far as that goes... Otherwise, good luck
i changed my axle bushings in about 30 seconds each.....i stuck a 1/4" drill bit in between the rubber and the steel....and the drill was spinning i pulled back slightly and it walked the rubber right out
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
