take a look at this intake manifold!!!!
Old 03-28-2007, 07:24 PM
vtecwho
vtecwho's Avatar
Default take a look at this intake manifold!!!!
i took off my upper intake manifold and this is what i found.... any ideas?? valve blow by maybe??
vtecwho is offline
Old 03-28-2007, 07:26 PM
grumpyphillips
grumpyphillips's Avatar
Default RE: take a look at this intake manifold!!!!
That is nasty looking. I've never seen that before. Is your car running like crap?
grumpyphillips is offline
Old 03-28-2007, 07:30 PM
cassidymustang
cassidymustang's Avatar
i was just guna say blow by of some sort. whats done to the car?
cassidymustang is offline
Old 03-28-2007, 07:34 PM
vtecwho
vtecwho's Avatar
no the car runs strong... just not as strong as a car with gt40 upper lower, gt40 heads, svo roller rockers, full exaust, ignition. i dont know what to do. its my DD but im tempted to take it all out and start over. i would try to have it done in about 2 weeks. got any ideas???
vtecwho is offline
Old 03-28-2007, 07:35 PM
I3atR!ce
I3atR!ce's Avatar
is the car modded? i would say your pcv system is sucking up oil, or your pulling oil in through your valve covers. do you have after market cover? is the baffle on your stockers on? do you see oil in your TB?
I3atR!ce is offline
Old 03-28-2007, 07:45 PM
vtecwho
vtecwho's Avatar
yea the car has many bolt ons. see above. the pcv seems to be working well. there is NO oil in the TB but the upper intake looks horrible! i did a compression check on it a little while ago and it took 3 rotations of the engine to pump up to 150 psi. i thought that was pretty high. like the pics show, only a few are sh*** looking the rest have mild residue
vtecwho is offline
Old 03-28-2007, 07:52 PM
vtecwho
vtecwho's Avatar
when i look down at the valve on a gumed up port, it looks dry with NO residue. the residue stops right after the lower manifold joins the heads.
vtecwho is offline
Old 03-28-2007, 10:16 PM
92hatchLX
92hatchLX's Avatar
Is that a GT40/Explorer or a Cobra intake?
92hatchLX is offline
Old 03-28-2007, 10:24 PM
dman302
dman302's Avatar
Most intakes will pull oil inside the intake..past the filter screen, past the PCV valve and into the intake...in due time it will make it's way into the ports, likely somewhat blowby related.
dman302 is offline
Old 03-28-2007, 10:56 PM
vtecwho
vtecwho's Avatar
both are upper and lower are gt40 intake. is anyone framiliar with 1.72 rollers and a after market cam?? will a high duration cam cause the valves to hit with 1.72 rockers??
vtecwho is offline
Quick Reply: take a look at this intake manifold!!!!
