whistles like a bird, my manifold. SOLVED!!
Old Apr 3, 2007 | 12:22 AM
  #21
92hatchLX's Avatar
92hatchLX
Default RE: whistles like a bird, my manifold. SOLVED!!
So your TPS was messing with the IAC?
Old Apr 3, 2007 | 12:31 AM
  #22
house302's Avatar
house302
so you just replaced the tps and the whistle went away.
Old Apr 3, 2007 | 12:56 AM
  #23
vtecwho's Avatar
vtecwho
im horrible at electric stuff but if the IAC is the thing on the TB opposite of the EGR, then yes. my mechanic explained it to me and the IAC was letting in air via two small whistle making holes in the inside of the IAC.
tell me i have helped someone out with the same problem as me. i could NOT figure it out so i have spent 150 bucks to fix it and would like others to benifit from it!! good luck
Old Apr 3, 2007 | 01:05 AM
  #24
86 5.0L's Avatar
86 5.0L
is it the cylinder thing that says ford what you're talking about?
http://s9.photobucket.com/albums/a10...t=MOV03338.flv
Old Apr 3, 2007 | 01:13 AM
  #25
vtecwho's Avatar
vtecwho
the photobucket is not working for me, i dont know why. but yes it is a tube or cylender looking thing. from what i understang there is a mechinisim that opens the two little holes in there to leak air in, thus causing the whistle.
Old Apr 3, 2007 | 01:53 AM
  #26
86 5.0L's Avatar
86 5.0L
www.modded mustangs.com/cleaning-your-iac.html
take out the space
Old Apr 3, 2007 | 02:16 AM
  #27
vtecwho's Avatar
vtecwho
yes, that would be it. it looks diff. on mine because i have a BBK TB but same shiz diff. smell. if your all out of ideas volt meter your TPS and see if its good. if not, a replacement will save you alot of whistle and performance. the noise may not be the tps or the iac, just a good place to check. my car would NOT whistle at idle but would make a ear-pearcing whistle at 1200, and beyond that you could just hear a whistle. my check engine light was also on.
is your upper to lower manifold gasket sealing right? ie have you taken it off lately??
Old Apr 3, 2007 | 02:21 AM
  #28
86 5.0L's Avatar
86 5.0L
ORIGINAL: vtecwho
this car hasnt been molested in 21 years [&:]
mtgldr
Feb 3, 2024 09:00 PM
Golfsito
Oct 6, 2015 11:02 AM
Shadow7874
Sep 24, 2015 09:06 PM
mltdwn12
Sep 23, 2015 08:54 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
