Surging Idle, at startup.
Old 04-04-2007, 10:16 AM
tmajikman
tmajikman's Avatar
Default Surging Idle, at startup.
O.k. here is what I have discovered, I had a post about my ac cutting the engine off. Well I started thinking about how my car acts when I first start it up, normal temp. or cold. The motor turns over great and for about 10 seconds it searches for idle, goes from 500 rpm to right at 900 rpm and stays at 900 rpm, runs great at this point. The ac does the same thing if I sit at idle if I turn the switch on then off. The car is sd, and I bought the car with a cai, I checked the iac out with another one I had laying around and it did the same. What are your thoughts on this? btw I am not worried about the ac, I can get around it for now, if I cure the idle issue, I think it will cure the ac issue. The only vacuum lines that are not connected are the ones going to the smog pump. sorry for the book.
tmajikman is offline
Old 04-04-2007, 10:47 AM
aode08
aode08's Avatar
Default RE: Surging Idle, at startup.
ORIGINAL: tmajikman
I didnt know the smog pump had any vacum lines.
What happened to the lines from the smog pump to the rear of the cylinder heads? Are they plugged?
aode08 is offline
Old 04-04-2007, 10:52 AM
tmajikman
tmajikman's Avatar
ORIGINAL: aode06
ORIGINAL: tmajikman
Well the smog stuff is still on, not the main hose, I need it plugged, it looks like there a black and white vacuum hose thats needs to be plugged, they go to something for the smog pump, I beleive.
Old 04-04-2007, 10:57 AM
namor1235
namor1235's Avatar
The ac does the same thing if I sit at idle if I turn the switch on then off. The car is sd. wat do u mean? THE CAR IS SD. ur on the right track from wat i readi dont understand that (SD)but try buying a bottle of brake cleaner and spraying it on the intake manifold or any vacuum lines to see if there is a rpm change to locate a vacuum leak
namor1235 is offline
Old 04-04-2007, 11:01 AM
aode08
aode08's Avatar
aode08 is offline
Old 04-04-2007, 11:16 AM
samseed101
samseed101's Avatar
Yes the smog pump / thermactor has vac lines that connect to it. And if you have open / disconnected lines, you probably have a vacuum leak. Spray some carb cleaner around the lines and around any other vacuum lines with the engine running and listen for any changes. That will give you a rough idea of where the leak is (if you have one.)
samseed101 is offline
Old 04-04-2007, 04:22 PM
tmajikman
tmajikman's Avatar
thanks for the advice everyone. I now have something to investigate on why it does some funky stuff.
Old 04-04-2007, 10:54 PM
bambam01
bambam01's Avatar
Try to readjust our throttle body. It fixed my trouble it was doing the same thing. Good luck!
bambam01 is offline
Old 04-04-2007, 11:27 PM
tmajikman
tmajikman's Avatar
I messed with the idle, and the surging only happens when I first start the car and when I turn off the ac. I need to look into the vacuum lines first, I know there are a few off. If the smog removed can I just plug those vacuums at the time.
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Surging Idle, at startup.
