no reverse lights?
ok ive got a minor problem i have no reverse lights. the signals and brake lights wrk but no reverse. i tested the socket with a test light and it was dead. i checked the fuse but it was good. what else can it be.
ORIGINAL: tmajikman
could be the reverse light switch itself, or a loose or corroded wire, or a bad ground. Check the switch first.
ORIGINAL: bbbngowc
Sorry to bring back such an old post but ... was there a fix? Why do people post problems then don't post the solution????
I have the same problem and need a solution.
Or it's too complicated and you get no responses.
Another thing is lack of basic manners. Like when someone answers a question to your solution. A thanks or it's now fixed its pretty rare here. I think it's just the general population here is young people and we all know most young people are lacking basic manners.
As for the reverse light switch. I'd start with the switch on the transmission. It's most likely a normally open switch and it should go closed when the trans is in reverse.
It will be the 2 prong switch on the side of the trans.
Thanks Jfsram.
Just got it fixed today by accident. I don't have any turn signals, so I bought a new turn signal flasher and whadda ya know, turn signals still don't work but the reverse lights now work [&:]!!!
I have an electical diagram and it showed that the reverse lights connect to the turn signal flasher. Go figure.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
