HP combo
HP combo
what is an HP estimate of this combo???
1994 GT
-302 stock bore
-main girdle
-hv oil pump
-7qt pan
-b303 cam
-billet timing set
-ported and polished e7 heads w/ dual valve springs, hardened retainers and keepers and p rods
-long tube headers w/x pipe into flowmasters
-255lph f pump
-42lb injectors
-vortech supercharger 8lbs
-billet steel flywheel
-underdrive pullies
-80mm maf
1994 GT
-302 stock bore
-main girdle
-hv oil pump
-7qt pan
-b303 cam
-billet timing set
-255lph f pump
-42lb injectors
-underdrive pullies
-80mm maf
RE: HP combo
A guy near me has the same combo with subtle differences. You have P&P'd heads with stock intake, he had GT-40 Intake and stock heads. His numbers came out with 340ish hp and 380ish tq, after being dyno tuned.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
