Trick Flow???
Trick Flow???
I know i want a trick flow intake and heads, but my question is which one should i go with. Track Heator Street Heat for intake and Twisted wedge or Track heat for heads?I am going to do bolt ons and juice so which would best suit me. Also if i get H/I what should i get for a cam i have a stock bottom. Thanks
RE: Trick Flow???
ORIGINAL: 94StinkinLincoln
get the edel heads and rpm2 manifolds with what ever cam u want
Also off the subject i just bought a bbk 70mm TB would it be wise to make a blocvk off plate for the egr and just get rid of itor is that a bad idea
RE: Trick Flow???
look around for cams, there is a thousand of them to just ask some stranger on the net what they want u to get is not the best idea. i would suggest lookin at comp cams, their stuff is really really good. the engine builder i worked wit swears by them. but its up to u there is good stuff by crane and trick flow has good cams. lunati is good too. look at them and decide on what u want. one thing i would say is be careful of the cam u choose for the sn95 comp is a little picky.
RE: Trick Flow???
get rid of it if ya want...im takin all my emmissions stuff off. i was origionally gonna get the TF track heat kit...found out they adverage around 320 and not the 350 they say...i was gonna get the AFR heads but there is a long wait and u have to get the spring upgrade...the eddy's are a little cheaper...i got mine from jegs for 1,285. and the rpm2 manifolds show good #'s. look at my sig...
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
