question about coil grounding
does any one know if the four little bolts that hold the coil to the mounting bracket are also use for grounding the coil? I am asking becaause I want to move it and if it needs to be grounded then I cant put it where I want to.
A coil does have to be grounded. Any electrical circuit requires a complete path, hence the name circuit as in all the way around. Any induction coil in actually two coils like a step up or step down transformer, except instead of AC the ignition coil only works by stepping up the voltage based on the field collapse of one pulse. Many ignition coils have the secondary coil (high voltage side) grounded through the coil body, so they do need to be grounded to have an electrical path for the spark to jump to, unless the ground is shared with the low voltage coil. Clear as Mud?
I know what you're saying but I don't think the secondary side is grounded except by the current flowing out through the coil to the spark plugs where it jumps the gap to ground. and on the primary side, in the old point systems, the ground was via the condenser which acted like the shock absorber in the system when the points opened which causes the primary field to collapse creating the secondary current surge which fires the plug. I don't have a clue how this works with the new electronic ignitions though and you may be correct and I'm wrong.
If it does need to be grounded, you can still move it somewhere else and just run a grounding wire over to the coil from a good ground point on the chassis or engine block, so feel free to move it wherever you want to put it notso.
musnicki
Sep 23, 2015 07:11 AM
jaiidutch
Sep 14, 2015 10:29 AM
