HELP!!!! Clutch
Old Apr 12, 2007 | 11:15 PM
  #21
Streetracer911's Avatar
Streetracer911
Default RE: HELP!!!! Clutch
anyone else have any opinions? I dunno why its so hard to find my answer this time[&:] normally someone always answers my questions quickly
Old Apr 12, 2007 | 11:41 PM
  #22
90Lxstanger's Avatar
90Lxstanger
Wow looks like whats on my car-until i snapped the cable.
Anyway- that cable is adjusted where its conncets to the fork-of thats what you have the craw under there and tighten the b*tch up where uou like your pedal to engage-and that'll be it!
Good luck
Old Apr 12, 2007 | 11:47 PM
  #23
8Mustang8's Avatar
8Mustang8
you can pull your car up on ramps, get underneath it have a friend push on the clutch put a c clamp on the peice of metal were the clutch cable goes to, let off the clutch so the cable is loose, then there is a screw on the end of the cable, tighten the screw a 1/4 inch or so. push the clutch pedal back in, remove the c clamp, and test it out to see if it makes any difference. thats how i adjust mine, i have a bbk firewall adjuster but it doesn't work so great or its broken or i'm just a dumb *** and don't know how to use it. i just barely did ^ this^ with mine.
Old Apr 12, 2007 | 11:49 PM
  #24
Streetracer911
well I tried to take off that cover type thing but the damn bolt is stripped!! do I really need that cover?
Old Apr 12, 2007 | 11:50 PM
  #25
Streetracer911
ORIGINAL: 90Lxstanger
Good luck
ok so now in english please!! lol. This sounds easier then the other guys input. thanks for helping
Old Apr 13, 2007 | 12:01 AM
  #26
90Lxstanger
ORIGINAL: Streetracer911
ok look at that link that you just gave me and look at the cable end. Its the same thing in my car[&:] look at the end of the cable. That white thingy
Ok the end of the cable(the gold threaded peice with a nut) that goes through the clutch fork(the peice that sticks out of the tranny)- take and look and you'll see. Get under your car and tighten the nut up on it until you get you pedal where you want it
Thats is IF you have that cable- id imagine yours is stock- actually according to your picture that you posted, im 99% positive that its stock.
So if it is, your best bet might be to get a new Ford cable- let us know
Old Apr 13, 2007 | 05:59 PM
  #27
Streetracer911
maybe ill just buy the kit and then adjust it through the firewall. Its much easier to do it through the firewall then to get under the car and such
Old Apr 14, 2007 | 06:55 AM
  #28
dvargas's Avatar
dvargas
It looks the same because it's the same cable. Put the car into first gear before you try putting it in reverse. This will stop the synchronizers from spinning and allow you to put the car in reverse without grinding.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
