just removed heads and found this
RE: just removed heads and found this
Any chance something got sucked up in there or forced in there with the turbo setup? How good of a filter / screen were you using? If I had to guess, I would say that it may have been a small metal fragment that broke free from the flowmaster after it was cut open.
Yep a small piece of slag was prolly the culprit. It's not bad enough to replace the pistons though # 7 looks like it got the worst of it. Fawk what a **** off.
see how it is on top of the pistons,funny its the same on both pistons!!!!looks like he is detonating and burning the pistons up.
need more gas less timing???but then agina what do I know???
You know I thought the same thing. But there is also pits on the head as well in the exact same locations. I am running 8* timing with the vacuum advance removed on 91 ocatane. So I really doubt it's detonating.
91 octane thats really low on a turbo motor how much boost?
its just a lil funny how its all in one place not all over the piston???
and its the same on both pistons wierd..
by the way your setup is awsum I love what you did......
and you did it all yourself NICE!!!!!!!!!!!!!!!!
