Squeaking from rear while driving
When driving i can hear a squeaking noise coming from the rear that pulses. I'm thinking it's a stuck parking brake cable because it hasn't really been working, and i have the wheel off and the cable seems pretty tight. How do i relieve the tension on the cable, or is it something else?
Oh yeah, the squeaking goes away when you apply the brakes.
Thanks for the help. I hear it mainly when coasting with the clutch in, because of engine noise when accelerating. Then it goes away when i press the brake pedal. That's why i had the idea of a messed up parking brake. I had it all torn apart earlier today, did some pounding and spraying with brake cleaner, and put it back together. Took it for a drive a little while ago, and the squeaking isn't as loud. Maybe i should do a little more pounding [&:]
