quick ?
Old Apr 19, 2007 | 05:30 PM
lxdan93's Avatar
lxdan93
Default quick ?
it just started doin this like a couple weeks ago but say when i first start it and go to pull it out of the garage it acts like it wants to die and when i go down the road it will make popping noise under the hoodfor a min then go away... but when i park it weather the motor is hot or cold when i start it back up it does the same thing? what could it be?
Old Apr 20, 2007 | 06:21 AM
lxdan93's Avatar
lxdan93
Default RE: quick ?
someone out ther has to know.....
Old Apr 20, 2007 | 05:27 PM
lxdan93's Avatar
lxdan93
Default RE: quick ?
well guess ill start with the spark plugs (even tho there new) and go from there
Old Apr 20, 2007 | 05:43 PM
samseed101's Avatar
samseed101
Default RE: quick ?
Are you running too lean by any chance or do you possible have a vacuum leak?
samseed101's Avatar
samseed101
Default RE: quick ?
I'm not sure what you mean by Popping noise. Is it like a popping, or closer to a pinging...like a marble in a paint can being shaken? If that's the case it could be detonation which could be a result of a vacuum leak (causing you to run lean.)
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
