About how much hp am I pushing to the wheels and to the flywheel?
RE: About how much hp am I pushing to the wheels and to the flywheel?
RPM or Typhoon would breath better in the upper range where the X will like it..the performer might choke you after late 4000s. Port job will detrermine how well the heads will breath and springs to determine how the valvetrain likes the extra lift. Again check clearance before buttoning her up.
sorry man my pocket dyno is down
ORIGINAL: 89GTdude
About how much hp to theflywheel and to the wheelsmy 895.0 will bepushing because I honestly have no clue? Im currently building everything right now!
Here is a list of all the major parts I didn't include little things like hardened pushrods, double roller timing chainetc.
Edelbrock Performer upper and lower intake
Ported and milled 70 DO0E 351w heads (better then Gt40)
Ford Racing X303 Cam
Pro-Form 1.6 Roller Rockers
70mm Throttle body
C&L 76mm Mass air meter with tube (calibrated)
24 pound injectors
70mm throttle body
Dual electric fans
Timing advanced to 14*
Underdrive pullies
JBA headers
Bassani offroad x pipe
Magnaflow Catback
Assuming everything is in perfect running condition and car is dyno tuned, how much hp would you estimate its putting out?The bottom has low miles on it and It has new plugs, wires, cap etc. and is a T5 with a aluminum driveshaft!
70mm Throttle body
24 pound injectors
70mm throttle body
Dual electric fans
Underdrive pullies
JBA headers
Magnaflow Catback
