STARTER SOLONOID
STARTER SOLONOID
i bought an 89 gt...it had a "security system" rigged up badly...i bought a new starter solonoid and battery cables and im trying to eliminate the security crap but im not sure what all is supposed to be on the starter solonoid...can someone help me out...
RE: STARTER SOLONOID
im fair pretty sure that there is 3 a big ground cable a big power cable and the third is either a neutral wire or the ignition wire for when you turn the key that tells the started to start cranking.
there is no ground cable. being bolted to the fender is what grounds it. both large cables are power, one is incoming from the battery, one is outgoing to the starter. the other wire is the ignition signal from the key, after all the safety switches..
dude, dependin on wuts goin on sunday, im suposed to hang out w. that chick, but if i dont ill bring my car over ur house and we can compare it to that... well get that bitch runnin
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
