<~ recommends using a hardened oil pump driveshaft when installing a new pump in a small block ford. those like to twist, especially if you run a HV or HP pump. they are less than 20 bucks too, so its cheap insurance.
rule of thumb is if your rebuilding a stock or slightly modified 302 the two most important things to upgrade is the oil driveshaft and the 5/16 rod bolts (to stronger 5/16 rod bolts, not going bigger to a 3/8 bolt)
