Flywheel!!!!!!!!!!!!!!
Old Apr 24, 2007 | 02:47 PM
jjp278's Avatar
jjp278
Default Flywheel!!!!!!!!!!!!!!
What is the main difference between aluminum and steel flywheels? Will it make a significant difference if I choose one of the other?
Old Apr 24, 2007 | 03:01 PM
hellion_79's Avatar
hellion_79
Default RE: Flywheel!!!!!!!!!!!!!!
steel is made for those people who like to ride the clutch
Old Apr 24, 2007 | 03:09 PM
samseed101's Avatar
samseed101
The biggest difference is that one is made from aluminum and the other is made from steel. I forget which is which.
mattdel's Avatar
mattdel
hahaahaha[sm=funnypostabove.gif]
Old Apr 24, 2007 | 03:12 PM
67mustang302's Avatar
67mustang302
Aluminum is lighter and lets the engine rev quicker, steel is heavier and lets the engine run smoother(especially at lower rpm). The flywheel has weight in it in order to maintain rotating inertia between power pulses(every 90 degrees in American 90deg v8's). Lighter flywheel doesn't have as much inertia, so the engine may idle rougher and run a bit rougher at lower rpm, but less inertia also means it can be accelerated more quickly
Old Apr 24, 2007 | 03:13 PM
hellion_79's Avatar
hellion_79
Im guessing it is for people who are tryin to make thier cars lighter. But I am sure a steel clutch will last ALOT longer, depending on if you know how to drive a stick or not.
Old Apr 24, 2007 | 03:43 PM
nseoi's Avatar
nseoi
if your getting a new one might as well spring for the aluminum one. faster revs, less weight, and the contact area has steel on it anyway
Old Apr 24, 2007 | 04:15 PM
hellion_79's Avatar
hellion_79
ORIGINAL: nseoi
true true
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
