Tie Rod End
Old 04-27-2007, 02:41 AM
92cobra
92cobra's Avatar
Default Tie Rod End
Hey I just went and got 2 new rear tires, and the guy looked at my car while he was installing them and said i had a broken tie rod end. He said it was 80bucks for the part, and 120 for the labor. Does this seem reasonable and should i supply the part or should he?
Thanks for your time.
PS I know its broken because i can feel my car sway abit.
92cobra is offline
Old 04-27-2007, 02:46 AM
mattdel
mattdel's Avatar
Default RE: Tie Rod End
****ttt no. first of all, tie rod ends are around $20 for outers, and aroudn $35-40 for inners. secondly, both of them are cake to do yourself, but a shop shouldn't charge you more than an hour, plus an alignment
mattdel is offline
Old 04-27-2007, 03:01 AM
92cobra
92cobra's Avatar
oh, well they didnt even include the alignment i dont believe. So i will make sure to take her somewhere else. Is it safe to drive it for a week or so until i can get it done.
92cobra is offline
Old 04-27-2007, 03:08 AM
mattdel
mattdel's Avatar
that all depends on how bad it really is. if its just barely starting to get loose, you should be fine. but if its ready to fall out of its own socket, you shouldn't drive it.
if you have access to a jack, jack up that wheel from underneath the control arm. then when it's in the air, shake the tire from side to side, and corner to corner. if it's really loose, you'll be able to feel it.
mattdel is offline
Old 04-27-2007, 03:12 AM
92cobra
92cobra's Avatar
I dont think its terrible because im just swerving a little bit. But i wont drive it to hard or to often until next week then.
92cobra is offline
Old 04-27-2007, 03:21 AM
92cobra
92cobra's Avatar
got a link to what i need to buy?
92cobra is offline
Old 04-27-2007, 03:29 AM
mattdel
mattdel's Avatar
couldn't tell ya. there is more than 1 part that could be bad. he could be trying to swindle you, you could have broken sway bar links. you should take a look for yourself, maybe take some pictures and post them here. also try what i suggested earlier.
mattdel is offline
Old 04-27-2007, 03:31 AM
92cobra
92cobra's Avatar
alrighty will do man, thanks so much for your help. I guess after this i can start saving for my suspension heh.
92cobra is offline
Old 04-27-2007, 04:09 AM
Blckstng93
Blckstng93's Avatar
$80 for a tie rod and $120 for labor?
[sm=roll.gif][sm=roll.gif][sm=roll.gif][sm=roll.gif][sm=roll.gif]
What was this guy smokin!?
Blckstng93 is offline
Old 04-27-2007, 06:04 AM
92cobra
92cobra's Avatar
heh im not sure but i really hope that i can find it cheaper. Maybe while ive got it at the shop i should have them rebuild my trak lok also, anyone know what that will cost?
92cobra is offline
Quick Reply: Tie Rod End
