Alarm
Old Apr 29, 2007 | 12:55 AM
Bagitupbaby's Avatar
Bagitupbaby
Default Alarm
i got a 91 LX 5.0, it has an alarm on it that has keyless entry, i wanna get rid of it does anybody have any instructions on how to do this properly?
Old Apr 29, 2007 | 01:00 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Alarm
Locate the brain of the alarm. It will be hooked to the main feed of the ignition switch. Remeove the wiring from the brain and connect the 2 factory wires back together.
gizim_1132's Avatar
gizim_1132
Default RE: Alarm
I would try the electronics forum that's your best bet!!!!!
Old Apr 29, 2007 | 01:14 AM
Bagitupbaby
Default RE: Alarm
its next to the fuse box, there is alot of wires going into them two little boxs one is the alrm box and there is a shock sensor one? do i just disconnext both boxs? and match up the color wires?
Old Apr 29, 2007 | 01:17 AM
5pointslow91's Avatar
5pointslow91
Default RE: Alarm
why u wanna get rid of it?
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Alarm
Pull all that crap out. Like I said, the only thing you need to do it connect the ignition feed back together
Old May 1, 2007 | 12:22 AM
Bagitupbaby
Default RE: Alarm
i finally got it out i cut the brain out and the wires are intact in a harness i just zip tied it to a bar underneath the steering wheel , thanks
Old May 1, 2007 | 12:25 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Alarm
See, simple enough
daytooday
May 2, 2018 05:56 PM
JoshyGT
Sep 7, 2015 02:04 PM
sykopafikjuggla
Jan 31, 2005 11:05 PM
sykopafikjuggla
Jan 20, 2005 03:47 PM
MacDiesel
Nov 3, 2004 12:18 PM
