suspension
suspension
im thinking about adding the following to my car, let me know watcha think.
Subframe Connectors
http://www.latemodelrestoration.com/...1&comp=LRS
50dollars + install
Rear Upper and Lower Control arms
http://store.summitracing.com/partde...p;autoview=sku
219.95 + install
Shocks Strust Springs Kit
529.95 + install
Hows this look and if you had to guess the total for install, or each install price, what would you guess?
Subframe Connectors
50dollars + install
219.95 + install
529.95 + install
RE: suspension
i thought about strange, but i dunno, adam is obsessed with his lol.
adam = dimebag
i do agree with the subframes and the upr upper and lower, i guess i will go with those instead, thanks man.
adam = dimebag
RE: suspension
I have the throught the floor subframes in mine that I made myself from 2x3 square tubing. If you are going to make some power and leave hard be careful when you buy control arms. I bought some cheap ones and after a couple of passes on ET Streets with some 1.60 60's the bushings broke and I ovaled the holeswhere the bushings go. I now have Steeda adjustable uppers and UPR lowers. I run the Strange struts and Lakewood shocks. For springs I have Eibach pro lowering springs. I am sure with the drag launch Eibachs or 4cyl springs it would be better but with what I have it doesn't do to bad at all. Don't forget torque box reinforcements.
RE: suspension
ORIGINAL: 92GreyGT
Im going to be swapping out to a nice set of MM's when I have the money!
RE: suspension
Maximum motorsports full length subframes, Summit upper/lower control arms (no issues here), Eibach drag launch springs in the front, FRPP C springs in the rear, Strange 10 way adjustable shocks and struts, Nitto 245/50/16555r Drag Radials.. That's the route that I went and the car launches and hookslike a son of a bitch, I think that I might have a few other suspension mods that I left out.
RE: suspension
Summit now sells a kit with strange struts/shocks, hotchkis cc plates and H&R springs (I think) for like 600 bucks. Look into it, its a good kit. As for those summit control arms, thats why I just always put out the extra cash for good parts. you get what you pay for, its sounds retarted saying but it couldnt be more true.
Matt's 95 Stang
10-05-2015 07:16 AM
