clutch adjustment?
RE: clutch adjustment?
Mine did the same thing I had to buy the triple pickup and the firewall adjuster so I could adjust mine or you could just get a replacement cable with the adjustment nut on it.the firewall adjuster is the best way to go its easy just pop the hood and turn it if you just get the cable with the nut on it you gotta get under the car to adjust it good luck
junior04
09-28-2015 10:53 AM
