Car shakes at 70mph...need help!
I have an 84 with 5.0 that I recently picked up. It drives nice until you get to about 70 mph and then it shakes from something in the driveline I think. It doesn't appear to be a steering issue however I have not ruled the idea out. The guy that had the car some time ago had a 351 in the car but left everything the same from what I can tell. It has a Tremec 5spd, stock driveshaft, 8.8 rearend with 373 gears.Does anyone have any ideas? I havesome of my own ideas but could use a little help figuring this one out. Thanks.
RE: Car shakes at 70mph...need help!
Could be a lot of things, bent or out of balance driveshaft. If you have a stock one they tend bend from racing on slicks. U joints can also do it. How do your motor and tranny mounts look? Tires could also just be out of balance.
Mounts are all brand new on the engine but I'm not sure on the transmission. Tires are ok. I was suspcious of the driveshaft being unbalanced or bent. I don't know if he ever ran slicks on the car but I would guess he did because the car is all set up for racing.
ORIGINAL: Highrpm
I had a buddy with that exact problem. The fix for him was a transmission issue. He had to replace a cracked portion of the transmission case. He had tried the driveshaft switch, wheel balancing, changed the fan...ect and it ended up being a very inexpensive part. I will talk to him tomorrow and get the exact name of the peice.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
