Getting air out of cooling system
RE: Getting air out of cooling system
take off coolant temp sender on drive side front of lower intake off
then fill till water comes out of it.
That is the highest point on the engine block and will bleed all air out
as filling.
Replace sender then start car and let warm up with radiator cap off.
once you see coolant moving and T-stat has opened, you should
be good to go.
as filling.
be good to go.
09-08-2015 11:50 AM
09-01-2015 08:16 PM
