Convertible pump, fill fluid?
Ok, I see the pump. But how do I put the fluid in? I see the connections but there is no fill cap, and the lines are connected to the pump. It's a 1994 5.0.
RE: Convertible pump, fill fluid?
The first time I filled mine I removed one of the lines and ran the motor so that it would suck the ATF and then made a mess and and the second time I did it right It is a small black plug on the motorthe size of a dime.dont over do it with the ATF when the top is down the fluid has to fill the reserve
