Which sandpaper grit should I use
RE: Which sandpaper grit should I use
hell no, use 80 then 120 on a orbital sander then 220 on a block, otherwise u will be there sanding all day
ORIGINAL: hatchdemon89
220 just to be safe use a block sander an dont put pressure on the block or you will get a uneven level
not when its wet, semy dry and moist. Cheese grate it. goto the home depot and buy a cheese grater in the tool section. File iot down then start sanding with 180 trhen 220.
i never mess with it till its all the way dry, sometimes theres spots that might be wetter than the rest and u will take too much off. or creat a pocket by moving it around. grater works fine when its all dry too. if u sand it when its not fully cured it will just gum up your paper
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
meechuacon
32
01-24-2007 05:28 PM
