Single wire literally only has 1 wire to hook up. Where it's bolted is the ground, and you run a single wire from the alt to the positive battery terminal, and the alternator has an internal voltage regulator. When you start the car and the alternator rpm gets high enough, it signals the alternator to switch on and start charging the electrical system. When you shut the engine off and the alternator comes to a stop, the switch shuts off
