3.8 to 5.0 conversion problems
Old May 12, 2007 | 02:58 PM
83convertible's Avatar
83convertible
Default 3.8 to 5.0 conversion problems
Ok I started out with a 83onvertible V6. I removed all the wiring in the car and replaced it with a 87 mustang GT harness ( the whole thing ). So when I turn the key the dash lights turn on and the box by the fuse box clicks but nothing from anything else. None of the relays are working ( fuel pump relay or EEC relay). I have replaced the relays and still nothing. Any help would be appreciated as I am getting very frustrated. I have checked all known connection but still nothing. I can make the fuel pump run by a jumper wire so I know the fuel pump is good. Thanks in advance.
Old May 12, 2007 | 03:24 PM
r.barn's Avatar
r.barn
Default RE: 3.8 to 5.0 conversion problems
sounds like a ground problem to me.
I would start there, triple check and upgrade all your grounds.
Factory ground set-up is mediocre at best.
Old May 12, 2007 | 11:26 PM
83convertible
Ok replaced all the grounds and still nothing. How do these relays work. I bench tested with a battery and the new ones test fine. What will hold out the fuel pump relay from kicking in? I am lost.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
