header problem
Old May 12, 2007 | 03:36 PM
GaryBisiniere's Avatar
GaryBisiniere
Default header problem
i have bbk long tubes on my car and there is a rattle coming from inside the header... i cant see what it is. does any1 have an idea on what it could be and how to fix?
Old May 12, 2007 | 03:50 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Default RE: header problem
Are they ceramic coated? If so I might be a ceramic bead.
Old May 12, 2007 | 03:51 PM
GaryBisiniere
yathey are how would i go about fixing that? cause its wicked annoying to drive it with this rattle.
Old May 12, 2007 | 04:02 PM
91ford302's Avatar
91ford302
the only way to reall check it out is to pull em off and figure it out. should only have to pull one side once you figure where its coming from.
Old May 12, 2007 | 04:04 PM
GaryBisiniere
ya i know what side its coming from... same side as steering colum so theres no way to get it out without taking motor out.
Old May 12, 2007 | 04:18 PM
Blckstng93's Avatar
Blckstng93
ORIGINAL: GaryBisiniere
Nice. Im guessing the motor went in with the headers already on? If not, why cant they come back out the same way? Its not touching the column is it?
Make sure everything is nice and tight, at both the engine end and the other end.
Old May 12, 2007 | 04:24 PM
GaryBisiniere
ya i put the longtubes on with the motor out. i have the h pipe off and im looking into the header and hitting it and i hear a loud rattle.
Old May 12, 2007 | 04:29 PM
Boss_Hotrod
Its easy to get the driver's side out. I think you can slip it right out the bottom. We had our tranny out when we put ours on and thats how we got it on.
Jb145700
Aug 21, 2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
